TPI Heavy duty fan kit
stock
Philadelphia, PA, USA
I searched and couldn't find any reviews. My 69 40 with stock 2f water pump shaft is starting to wobble. I also don't have a fan clutch, previous owners did some amazing ghetto work, so not sure if I had one in the beginning or not.
I see this one from TPI. Any feed back? FJ40 FJ60 HEAVY DUTY FAN KIT
No mention of a clutch.
Check out cruiser corps as well.
He has aisan pumps and clutches.
Local guys can get you a 7 bladed fan.
69 wouldnt have a clutch.
Just a direct drive steel four bladed fan.
It should probably be mentioned that the "stock 2F" in you 69' isn't stock so without pics it's hard to know what your fan/water pump setup actually looks like. The TPI kit is likely WAY overkill and I personally wouldn't spend the money on it. I'd replace the water pump and upgrade to a 7 or 8 blade plastic fan. It'll have no cooling issues then assuming the rest of the cooling system is in good order.
X2
Let's see what you're working with and we can recommend a solution.
Thanks Kurt. I emailed you guys first over the holiday then this TPI unit popped up. I could use your insight. Maybe I'll send a picture as well.
We are rocking through emails from the long weekend. If you've got a pic send it along via email, I won't be back on Mud til' this evening.
