Toyota Dealer March 2022 Major Discounts (2 Viewers)
I might just go ahead and drop the coin on one. Mine is fine and has been serviced regularly, but never know. Id rather 1k today than 2k next year.
There was a change on pressure switch so make sure you chose the correct master pump.
Only $1027.99 shipped.
This is great price.
Ugh, just put in a big order at McGeorge 2 days ago. Oh well, I'm sure I'll need more Cruiser parts soon.
I have a feeling all these big parts are going to be backordered and show up in another 3-4 months.
We'll see. I'm at 4 months and counting on an certain 2003 elusive transmission pan.
I did a little looking up of brake booster assemblies since mine is a 2000
47050-60010 year 1999 w/o stability
47050-60012 year 2000 without stability control also 2001
47050-60041 year 2000 with stability control also 1999
47050-60042 2001 w stability control
By vin lookup. My 2000 LC is the older 47050-60041
I ordered with my VIN so hopefully I get the right one. Just going to be banking this until the day I need it. So I'll have to carefully check the connections when I get it to make sure it's right
Does Toyota sell a timing belt "Kit"? The 100 I just bought is due for one and figure this might be a good place to buy that stuff. Or is there a better place to buy timing belt stuff from?
hit up cruiserteq.com
They have an Aisin kit that most of us use, and about half the price of the OEM gear. THey don't make a kit, so you end up having to buy everything seperate. I believe it runs about 450 or so doing it that way, verus 209 at Kurts.
Thats for non VVTI motors (98-05)
This right here. I just used the kit from cruiserteq.com and it was great. Very complete kit. Seals and all.
I also added in the fan bracket from them. Very reasonable prices, as always.
Well that was $750 of parts I didn't expect to buy today.
But man cant pass up a deal. Thanks OP.
Got 10 oil filters each for my LC and my Tundra (2.80 a piece!?), seal and bearing to fix my T Case leak, new door seal and cowls to fix some squeaks, the hose for the PS pump that's weeping, valve cover gaskets and plug seals, and some other stuff that I've been putting off.
16 products , 44 items
$760.48
Coupon
-$34.95
Shipping & Handling to USA
$34.95
Total
$760.48
You Saved
Dealer Discount
$452.66
Southeast Toyota March 2022 Parts Promotion
$253.43
Toyota - Free ground shipping on orders over $75 (max $200)
$34.95
Total Savings
$741.04
Hayesthebuilder - Thank you for posting this deal! I bought the following for my 2001 LX just in case I need it in the future:
P/N Quantity Price Each Description
90915YZZD3 6 $ 2.80 Engine Oil Filter
4705060042 1 $ 1,027.99 BRAKE BOOSTER ASSEMBLY, WITH MASTER CYLINDER
Order Summary:
2 products , 7 items $ 1,044.79
Coupon - $ 56.64 (Code: FREESHIP)
Tax $ 94.03
Shipping & Handling to Lower Alabama $ 56.64
Total $ 1,138.82
Thank you, really appreciate it! Other than fan bracket anything else I should replace? The truck has 202K miles on it, timing belt was done in 2015 at 115K miles so its due. I was planning on doing heater T's, serpintine belt, thermostat, radiator hoses and possibly the radiator as I believe its original.
Thanks for the heads up! I have a CV starting to make noise, 391 shipped for OEM is not bad at all!
I got my 2000 brake master pump from McGeorge for $1350 about a month ago. They charge tax and shipping on top of that. Now that I see it is at $1027, no tax and free shipping.... What should I do? I bought the pump to use in the future so it is still in the wrapper. Returning it clearly saves me $450!
You should return that s*** and buy yourself something nice with the $400 you saved
