What about the toyota TSB that states both red and pink are interchangeable? Personally I'd stick with known spec, but they did publish that doc which states you can mix them.
Gaijin, as I've posted here before, both the local Toyota and Lexus/Toyota service managers in the Boise area have advised me that the pre-mixed Toyota coolant is compatible with and can be used on vehicles requiring the concentrate. That said, neither stock the older coolant.Link to that doc?
Correct? Or am I up crap creek without a paddle here?
forum.ih8mud.com
Here it is. These coolant threads bubble up every few years. Personally I wouldn't mix, but Toyota claims you can.
Here's a good one to review.
Coolant Alert don't mix SSL (Pink) antifreeze in factory LL (red) systems.
Title deals with mix LL red Toyota antifreeze mixed with SLL pink. Which is ok but then you should use the more restrictive flush schedule of the red if done. Below is from Toyota COM concerning SLL antifreeze. The last line states: "Compatible with Toyota red Long Life Antifreeze/Coolant"...forum.ih8mud.com
Can you or somebody add this thread to the FAQ section on this forum...and maybe on the 100 Series forum?Great info. Thanks for posting it![]()
