Hi all.
Im new and this is my first post. Hopefully Im doing it right. Anyway I put a 5l in my hilux running a ct12b tubo, mech ip with compensator,3" exhaust from dump. Since Ive been running motor ive replaced the rear main seal twice and it still leaks after driving 2weeks. Boost is running 12psi, have pre turb EGT and oil pressure gauge. Im guessing there is to much pressure in the block and spits out the seal. Upon start up oil gauge reads 60psi then drops to 20psi when warm both @ idle. Doesnt get hot but the heater doesnt blow to hot either (just warm)... all pipes are fitted correctly running water and oil to turb. Has anyone had problems with rear main seal leaking in a plus t?
