crushers
post ho
i would ask how far you are towing and over what terrain. if you are towing on flat short distances then the ABILITY to tow SAFELY and COMFORTABLY is different than over a mountain pass numerous times.
I wouldn't worry about the fuel shutoff. The NPR trucks don't and idle fuel quantities aren't going to make any noticable difference.
But do the NPR trucks have an injection pump that is controlled by vacuum and mechanical governor like the 3B? Running down hill a 3B in gear will add fuel to the system. Wouldn't the governor in the injection pump add fuel due to engine RPM?
How did those coaster buses with 3B's deal with the issue
Tony
yeah really no muontains in my area, I am on coast area, will be mostly short and if long then will make a road trip out of it, will try short first and see how she does, if not I will to buy something that can pull it. Mine is however an overseas from AUS BJ and has the full float rear and I did buy a new Toyota exhaust brake from Japan 4x4 that was factory on some Coaster busesrunning 3B's and 1HDT's but have not installed yet. I only wish I did not swap my 4.11's out for 3.70's, will be swapping back out as soon as possible
Thanks
R
