tow bar
Discussion in 'Camping & Outdoor Gear' started by cruiserwanted, Feb 22, 2004.
  1. cruiserwanted
    cruiserwanted
    338
    May 11, 2003
    Elmwood, WI
    Anyone have a tow bar mounted on their FJ40? Where did you get yours? What brand do you recommend? How did your mount it? Did you drill holes into the bumper? Mount to bumper triangle (gussets) or did your take it all off and mount it to the frame? Thanks for all the help. :cheers:
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,305
    Media:
    17
    Albums:
    1
    621
    Oct 1, 2003
    MN
    Uhaul has ones that you can rent, along with car dollies... I would look into the dolly...
    Good luck!
    -Steve
  3. Mike S
    Mike S
    2,537
    14
    Aug 19, 2003
    I have a bumper mounted tow bar on my CJ2A, and have towed it thousands of miles with zero problems. This bar is adjustable and attaches to the bumper with a couple of U brackets and 1/2" pins. The thing articulates in a couple of directions.
    The CJ only weighs about 2200 lbs., has FF axles and locking hubs on all four corners - behind the Expedition, I hardly know it's there. An FJ40 weighs a LOT more than a CJ2A... and you will be spinning your diff /t case/tranny if you flat tow without disconnecting your rear drivehaft.
  4. CruisinGA
    CruisinGA
    6,164
    13
    Mar 27, 2003
    Georgia Tech
    I have the Smittybuilt one-piece tow bar that SOR sells.
    I do not have the stock bumper so I had to bend/modify the mounts a little bit, if you have a flat front bumper this is not an issue.
    Its great-tows at 90 no problem, I've had it all over GA and NC flat towed, even around town is not bad. I never remove the rear d-shaft, I just put the t-case in neutral.
    The only thing that you need in order to tow well is good caster. I added 2.5 shims after my 4 inch lift and never have any issues.
  5. Junk
    Junk
    6,177
    27
    Dec 13, 2002
    buggerville nj
    Had one and gave it away. They are cheap and easy to find.
