Tourflex rear coils
Pensacola, Fl.
Not sure how many of you are running these ,but wondering what shocks you're running with them? I have the adjustable tough dog shock and they do not seem long enough for this coil
At full droop, how far shy are you to connect shock to lower mount?
@Atwalz I will check that tomorrow but these coils are much taller than the stock ones.. but the tough dog shock is only a couple inches longer than the stock shock extended
so the measurement with weight on the truck - shock mount to mount is 23" (my truck is light, no extra weight in back only roof rack)
- the tough dog shock is only 25 1/2" extended, so that only gives me 2.5" of extended travel
@silverhorse Can you check the numbers printed on the tourflex springs. It should be 949-###?
Picture..
Interesting. I have tour flex on the rear with tough dog shocks.
Picture..
Two questions for you: Was this picture taken during install? We’re you able to get the top nut on the shock snug? I ask because the area highlighted below does not look right.
Thanks. I have same spring just wanted to make sure.
