Question for those that have installed TD lifts, I had the lift installed on my 2017 LC last week at the local Toyota dealer and have a 1" lean to the drivers side (i.e. driver's side is 1" lower than passenger side, front and rear) that won't correct. I've tried resetting the kdss and also the method of putting the block under the high side rear tire, no luck. Not sure if settling over time would correct. As instructed, the dealer put the taller RH spring on the passenger side, consistent with what it seems most folks on this forum have done, but could this be creating the lean in my case? If anyone here has run into this issue, did you find a fix? Would swapping the rear springs help correct (so the taller RH spring on the driver's side)?
