Totally separate Dual battery systems.
Burlington, Vermont
I've been doing some digging on dual battery set-ups, and am thinking about
totally separating my batteries.
I'm going to be adding another fuse block for accessories anyway, and with my Air compressor using the same belt as my existing alternator, I am thinking about just adding another alternator to charge the second battery. Does anyone see any huge drawbacks to going this route other than space ?
From my perspective Advantages are :
True battery redundancy (If the main power battery dies you switch the cables.)
True Alternator redundancy (If one alternator goes bad, I can just take the belt off the Air compressor and run just one alternator.)
No switches or diodes to add or go bad
I have another alternator sitting there begging to be used.
Systems are totally separate
Dis-Advantages:
Making it fit ( I think there is room.)
I barely have time to change the oil let alone add another battery and the accessories that require it !
How am I going to add a third alternator for the welder ?
I need some help here coming up with some more disadvantages..
I would love to hear your thoughts on this
Bill Atkinson
How to take advantage of the redundancy? Jumpers? In cab controls? How about TWO volt/ammeters? The advantage of having the batts connected but isolated means that you will never have to move the wiring for the engine and accessories wire harness to the other battery. Check the length of the lead to the fusible link... 'course, you could open the hood and physically move the batteries from tray to tray... why would you want do that?
2 alternators = more drag on the engine.
2 alternators = non standard belt system. Not a big deal, but a consideration.
Prolly some other stuff that I didn't list off the top of my head.
M
Vancouver, B.C.
Anybody else here gone down this road? I would like to keep my starting battery totally separate from my house battery. Sometimes I leave the truck for a week at -25. I need no possible additional load on the start battery.
MD,USA
I have a 2018 LC and I think this is what I will do, at least at first. I plan to have an Odyssey group 35 on Slee's mounting tray for the 2nd battery. The battery will just ride around unconnected to anything. If I need to charge it from my CTEK charger using shore power or my Goal Zero 1400 with solar panel I can. If I change my mind down the road and add a BCDC to charge the 2nd battery I can do that too.
EDIT: fixed a typo "ftom" to "from".
Vancouver, B.C.
I'm always carrying a spare alternator, so I thought I might as well use it to charge the second battery. Gives me redundancy if I have alternator issues in the middle of nowhere, which I've had before. Most of the research I've done leads me to not totally trust the two battery systems. Sometimes I leave the truck sitting for 2 weeks when I'm out on the land, so it is potentially deadly to come back to a flat battery. Sometimes the truck sits far from a power source in -30 for a week, so I want to keep the starting battery as risk free as possible. I can set the second battery and alternator up physically with normal levels of problems, but I'm having trouble mimicking the wiring scheme. Wiring is not my strongest point. Eventually, I want to add solar panels and a controller, but first, I want the house battery to charge while I'm driving.
