Hello,
I recently bought a 91 HDJ81. I mostly bought it because it was a 5 speed, low mileage, practically rust free, and within my price range. This is my first diesel. I have read the FAQ. This is a summary of what I have learned, and I would like some feedback and advice:
Summary & Questions:
Oil needs to be changed every 5000km. Change all filters.
Heat is the killer of these engines.
Need to get an EGT ASAP. Post Turbo. 1200 degrees is super bad. Want to stay between 400-600. Auber instruments is strongly recommended. Is there such thing as a Scangauge/Ultra gauge for this model diesel LC?
Change Big End Bearings.
Idle the diesel when starting (5 min), Idle it when done with driving it (if from highway driving 10 min).
Get an intercooler. (Do I need this even though mine is a 5 speed? If so what would you recommend?
Is any of this wrong? Did I miss anything to properly maintain this?
Concerns:
So I bought this LC to live out of when I quit my job and travel (2 years from now). I'm not mechanically inclined, but I do want to learn in the next 2 years as I will be on the road living out of this LC. I am told these are simple to work on. My concerns begin with searching this forum and seeing all of these scary questions of "X is making Y noise". I was always under the impression that these trucks were bulletproof; however, do I need to be mechanically inclined for that to be true? With all of the "babying" of this truck (idling to warm up and cool off, plus monitoring heat, oil levels, water temp etc) and increasing cost of parts, is this LC becoming the new G wagon/Land Rover in terms of maintenance and cost?
It has under 140k original miles. It has surface rust on the axels, and a small amount of surface rust on the body. Other than that it "seems" fine. Having a local mechanic look at it is $250 since they are an LC specialist.
Am I in over my head? Would a gas engine/newer truck be worth the extra $$$ for my current knowledge?
Thank you for your feedback and advice.
Concerns:
