I just did all my Front end bushings. I just put in the LCA and am trying to re-load the torsion bars. It seems like the anchor arm is trying to crab out of it's bracket as I torque it. Any ideas about how to counter this?
I used an electric impact and used my other free hand to push down and hold im place on the flat spot on top of what’s pictured. Tension will hold it in place once you get going. Lube bolt well before starting.I just did all my Front end bushings. I just put in the LCA and am trying to re-load the torsion bars. It seems like the anchor arm is trying to crab out of it's bracket as I torque it. Any ideas about how to counter this?
I used an electric impact and used my other free hand to push down and hold in place of the flat spot on top of what’s pictured. Tension will hold it in place once you get going. Lube bolt well before starting.
I just used grease I had on hand, red mobile 1. It seems to try and go over the rearward lip, maybe a large c clamp could help hold in place, or pry bar from above levering downward to hold in place? Sometimes it good to take 5 and give it some thought before continuing.I was using an impact too. Little afraid of sticking my hand in there. I did hold it to get it started and tensioned a bit. But when I continued torquing it started to crawl out. I was thinkiing about lubing the bolt, what do you use on it?
Are the front anchor bolts loose or tight, you can try adjusting there to give slack or tighten it up to help hold rear in place just a thoughtHeh, yeah, that's what I'm doing chatting with you!
Hmmm, I torque'd those to 166Are the front anchor bolts loose or tight, you can try adjusting there to give slack or tighten it up to help hold rear in place just a thought
Don't even think about sticking your hand in there if there is any amount of torque already on the torsion bar.
Also, are you doing it with the car being lifted (jacked up, so tbar is unloaded?) - that's a must IMO.
