The past few weeks I have been getting the VSC light and beeping constantly. I have cleaned the front wheel speed sensors, reset the ECU (removed battery for 1 hour).
Few symptoms that will trigger the VSC Alarm:
-Hard acceleration (anything over ~50% throttle.
-Any type of on-ramp that is a 270* turn.
-Speeds above 70MPH seem to trigger it for over 5 minutes (40% of the time)
-After the car wash, or heavy rain it goes off like crazy. I have checked all connections and harnesses to confirm no cuts, abrasions, or corrosion.
Few things that have happened-
-ABS and trac have intervened on the highway and pulled me into other lanes.
-VSC cuts throttle going through intersections
-VSC and ABS lights illuminated constantly until vehicle is shut off (most coming when coming from Low range to High range).
-ATRAC is still operational.
- No CEL or codes thrown, I have scanned while the VSC light was going off.
On to the torque steer...a few months ago I developed a torque steer, constantly pulling to the right when accelerating. I figured alignment, when she went onto the rack we lifted all 4 tires to check for play. On the driver side there is 0 play (of course a little, but nothing to be concerned about). However on the passenger side there was substantial play on the wheel @ 3 and 9o'clock. I would say 1.5" of play. Anyways, a few weeks ago I blew up a CV axle at Windrock. I was having too much fun in 2WD in the rain. However I did notice one thing...the torque steer is gone. It was awesome. Full throttle and it tracked dead straight. I replaced the axle and the torque steer is back. I have a feeling this is partially causing my VSC issues...
Symptoms of the torque steer:
-Any time throttle input is giving the truck will pull right, counter steering with the top of the wheel @ 10-11o'clock depending on how much throttle.
-Full throttle is all over the place.
-Under coasting, hard braking and through the corners she tracks beautifully.
-Cruising at 70MPH is effortless, a little wiggle in the wheel and the whole truck wiggles...no dead zone. However when I hit the gas the dead zone becomes quite large. Wheel must be put at 11o'clock, or I will change lanes. Makes it quite hard to drive in stop go traffic as I'm all over the lane trying to keep it straight.
-Torque Steer was present before I did the suspension swap/front end lift. It seems to be getting worse quickly.
I am thinking right now the inner tie rod is worn, as the outer seems fine. I can't see too far into the front end but it looks like the rack is tight and doesn't budge.
FYI- My suspension setup is as follows:
OEM Torsion bars (indexed and lifted to 2.8" lift)
Bilstein HD Shocks
OME 866+30MM Spacers (3.1" lift)
Revalved N74L with custom upper shock mounts and custom lower mounts.
No Sway bars F/R
Thanks in advance. I can take a video of the steering wheel during driving if that would help anybody diagnose. I'd rather track this down before I get sent into the trees on a mountain pass because VSC thought I was sideways at 70MPH
Bilstein HD Shocks
No Sway bars F/R
anyways, I have requested they save the old rack and I will disassemble the rack and take pictures of the inner workings. The tech is a 42 year old veteran that is certified on all Land Cruiser platforms and has more experience on the 100's than anybody I've ever heard of. Toyota flies this dude around the US for big jobs
