tool for putting bearings back on (1 Viewer)
hward1
87 fj60 / 95 fjz80
CA for little while
looking for what tool i need to install the bearing back on the i think output shaft goes between adapter case where transfer case and trans meet up -- also for putting gears back on - i wonder if auto supply stores have them to rent what ever they are - thanks Heath :bounce::bang:
Plano texas
Can you use a large socket to slip over the shaft and knock it down? Hard to know exactly what your working on by your description. MIke
Whidbey Island, WA
You should be able to use a piece of pipe. Get one that clears the shaft and presses on the inner race. Lightly tap it with a hammer and you should be good to go.
Same for the gears. Think tapping and not pounding.
The special service tools to do this are expensive.
I hope you have a service manual handy, would help with describing what you need
Tony
hward1
87 fj60 / 95 fjz80
CA for little while
thank you i will try it i have a pvc pipe i cut to try to work not a lot of room to tap but will try and see - thanks - the service manual doesnt show this i guess because when take the transfer apart i seperated the adapter case also so now i am dealing with this area -- or was this suppose to happen -- thanks again
Whidbey Island, WA
PVC won't do it, needs to be metal pipe.
Pictures would be a great help
Are you dealing with a four or 5 speed? And by "adapter" do you mean the spacer between the tranny and tcase? This spacer is held on by the tcase bolts so it probably needs a new gasket and to be resealed at the same time you reinstall the forward half of the tcase.
Tony
hward1
87 fj60 / 95 fjz80
CA for little while
it a 4sp and yes its the spacer between tranny and tcase -- i need to load up some pics - already got new gasket
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
