Is there a tool for fixing flattened heat tube?
Thanks
Thanks
Just bought it, I'll let you know how it works
I guess it depends on how the sizes match up. The tool is sized to swedge open standard copper tube sizes to allow making a joint without a coupling. Your tube could be right in between sizes. I guess you'll know soon enough. Anyway, not that expensive and you'll probably find other uses for it also. Hope it works.
People who repair instruments use ball bearings.
Find/get old school radiator man. Easier/faster/cheaper
Be curious if you end up having to cut this down to make it work. 6 5/16" with the widest section only 5/8" OD. For this tool to work on the larger pipes need a long straight section of pipe.
