To those who have painted their rims!!
Calgary Alberta Canada
Hey all,
What was the process for doing this?? How are they holding up?? any helpers, do's and dont's?? Please help!!
Thanks again,
I've had mine painted for a month and Ive been very happy with them. Its really very easy:
1.) Clean Wheels with degreaser
2.) Scuff up with scotchbrite pad
3.) Paint 2 or 3 coats.
The steps I took:
1) Remove wheels
2) Clean with dish soap (degreaser) and a plastic bristle brush
3) Dry with towel, then let air dry for a while
4) Tape off the wheel so you dont get paint on the tire
5) 3-4 LIGHT coats of primer, letting them fully dry before the next coat
6) 3-4 coats of whatever color paint, letting dry between coats
It took me a whole day of on and off work, but Im quite pleased with my results, and so far the only damage to the paint that I recieved was when I had my 305's installed, and that was because the Toyos balance without external weights, so they removed the ones that were there. Easy fix though :)
4dmalamutes thread on this has lots of opinions and options. the soap on the tire was a pretty cool trick that keeps you from having to mask the rubber; paint on and wash off the overspray. there are some good adhesion agents ( bond-aid ) that help prep metal for accepting paint that you use first like a primer.
The local auto refinishing supply store sells "etching" primer for metal-aluminium and this was recommended to me by more than one person.
Micah
For me it was:
1 - Find second set of rims that have peeling clear coat and look like crap
2 - Take rims to powder coater for sand blasting and coating
3 - Pick up rims, leave $200 and a cold case
4 - Sell my wheels and recoup all costs
For me it was:
Step1, Search
Step2, follow search results.
For me it was:
1 - Find second set of rims that have peeling clear coat and look like ****
:beer:
Thanks again for the help guys. I appreciate those who took the time to write something helpfull other then search!!
All the best,
Darren, i was just giving you a hard time. but it starts to get old when you explain the same thing 20 times.
I used "bond-aid" first after cleaning the wheels. Then i used dish soap spread onto the tire, but be very careful not to get any on the rim or the paint wont stick. Then i painted the rims black with a semi-gloss rustoleum product that is for auto trim. I used two coats. THen after it had dried i hosed off the soap from the tire and that also rinsed away any overspray.
Hope that helps.
Thanks again.. I appreciate it!! I just picked up a set that I want to paint.. .. and am eager to get into them.. .. .. I'll post some pics when finished.. Later!!
