Since I recently found out that 285/75r16 will fit my stock height rig, I'm contemplating whether or not to just get the stock replacement springs and shocks by OME or OME 2.5" lift. I'm using my truck more for getting myself to places a little out of the way, exploring, not rock crawling or anything like that. What do ya'll think?
the stock height springs on a non modified truck will yield about an inch lift and will require the OME bushings to get caster back to where it was. So they might work out real well for you for what you want to do.
Ok, to address, Lift or NOT... think thru the PROs and CONs
Pro: More ground clearance...and think about the COST per inch of extra clearance. That 2.5" will net you ZERO clearance between the axle and ground. (Bigger tires do that a 2" taller tire gets you 1 more inch of axle clearance)
It will add clearance between the rocker and ground though.
OR..plan B, you can simply add sliderz of some sort.
Looks good...and yeah they look sweet with 35s no doubt
CONS:
Cost...lots of money for that clearance / might be more efficient to spend the same cash on rocker protection which you "need" anyway.
Towing...you have changed the geometry from the $$$$$ setup that Toyota spent years perfecting and setting their Tow recommendations on. Maybe you don't tow.
Higher COG...this comes into play not only offroad, but in emergency manuvers (as does softer/heavier lift springs, lift geometry, etc)
For me, I have determined I want NO lift for now, I have lockers, getting sliders and I will hide a winch under the stock front bumper. I am running 285/75/16 MTRs and honestly, "where" can you take the rig with 35s that I cannot follow?
There WILL be a place or two every once in a while that the 1" extra axle clearance MIGHT make a difference...so I pull out the winch and ease over it. But to be honest, I have been trail riding for 12 years or so now and I have had rigs on 29-31s following me on my 36 TSLs.
For trail riding a stock Cruzr is one of the best rigs on the planet STOCK/285 MT tires. Throw on a winch and sliders and there isn't anything you couldn't try if you wanted to. Plus, you get to keep the stock towing characteristics, perhaps a bit better mpg, etc.
I hope this helps.
My only "concern" is the weight of that winch on my front 15 year old stock springs. For this reason only, I may end up going with some replacements from OME that are dialed in for my weight.
IF I knew 100% that it would not comprimise my towing and I was going to spend cash to get the "heavier" coils to offset my winch etc anyway, I might get the J (1" taller?) version or even the 2.5s you are talking about. But if it DOES effect it...not worth it imho for light wheeling purposes since I DO TOW.
you could get new stock springs, and even a 1/2" or 3/4" spacer, if you do not want 2.5" lift, but you arent going to save much money by the time you buy new springs, and shocks over getting a lift
I installed OME 861/862 low lift springs, which yielded about an inch of lift. The difference in driveability is huge. No more wallowing through the corners and nose dive under braking. Can't emphasize the how much it transformed the ride.
I've used Old Man Emu 'stock' height replacement coils on a couple vehicles, and have always been extremely satisfied with the improvement in ride and clearance. They say 'stock' but in reality you gain an inch or so. Not enough lift to greatly affect gas mileage or COG, but just enough to allow the truck to sit well on 285s, and perform better on trails.
The OME 861/862 have a significantly higher rate than the stock springs. They are well worth getting as they will make the vehicle handle better and support extra weight (no bottoming with 3 people in the back and luggage). Depending on your vehicle you may need the caster bushings even with the low lift springs. I would recommend if you are doing the low lift springs that you use Bilsteins as they have a much longer service life than the OEM or OME shocks and are a better design (high pressure monotube with digressive valving).
Personally, I would say get the OME 2.5 medium lift so you can get yourself into more places a little out of the way. You get more ground clearance in case you go exploring plus most OME lifts have the same prices.
Is there a thread on here that goes through the basic components of whats required in an 80 lift? I'm a newbie to lifts and my current 80 has now developed some sag in the rear due to an lpg conversion that I have had for 2 years now. I also occasionally tow a trailer (max 750kgs load not including trailer) and this has also most likely contributed to the sag. To address the sag I am contemplating a 2.5" or 3" lift kit. My truck is stock 1997 petrol Cruiser (with LPG conversion). I am considering doing this myself with the help of my brother who used to work on fire engines however I am not familiar with all the general dynamics of a lift. I realize that this may be the wrong place to post and if so please point me in the right direction. Thanks.
I had the stock height springs on my last truck with rancho shocks(which I actually liked) and currently have the 2.5 lift with bilsteins. In hindsight I really liked the stock height springs better than my current setup, although when I had them I always wished that I had bought the 2.5".
Either will be a huge improvement over stock and either can be sold in about an hour on here for nearly what you paid for them so it is not that big of a decision.
Since the cost is only about $100 to get lift versus stock height, I'd say lift. Earlier 4X4CPOSEADOG said that the extra height will get you into more places in the backcountry, and I agree. Like you, I have my Land Cruiser for trail riding instead of rock crawling and the 2.5 inch lift is just enough to get over a few more obstacles without substaintially compromising the ride quality. Also, as regards the towing capacity, the new springs should give you more tongue weight capacity and I don't think the max tow capacity would be affected very much. I mean look at all those guys who buy big American trucks and put 6" lifts on them (with blocks in the rear I might add--no where near the strength of attaching directly to the spring). Most of those guys still use that truck to tow their enormous travel trailers or whatever.
I would say lift as well, because if you are susceptible to this addiction, as most of us are, then you will wish your truck was higher. I did the J's and had to end up with the plates for caster correction, and will probably need a DC drive shaft too, soon. I still can tow my #5,000 plus catering trailer, and it tows well, pretty solid. Hope this helps.
I have the Bilsteins with the low lift springs and really like the performance of this set-up. The drivability and safety factor compared to stock OEM is night and day.
I'm also considering the Downey Off-road 2.5" lift that comes with Bilstein shocks at $685.51. The only thing needed is the front steering stabilizer. Anybody using this lift?
