So as this process of getting my 60 to run better system by system I have a question for you all. I had originally disabled my EGR by clamping the top hose and it ran great...no Ping..
I recently replaced the thermostat as mine was stuck open and never getting to operating temp. Now that I have gotten the 60 up to temp....damn thing pings in 3rd and 4th gear on long hills and some flat runs when I am up to 60-65mph. I adjusted the mixture and set the timing....the BB is just below the line in the window.
I unclampped the EGR hose and now it is chuggy/sputtery as hell (like it was before)....and upon accleration the vac gauge needle sputters like hell and is reading like 5" but no ping at all. The EGR tests out fine...the modulator is probably toast...I am not sure...
This 60 is smogged and will have to pass emmisions soon.
Should I Disable the EGR and just retard the timing till no ping....is that a good idea? Anyone have an idea how far to retard..is it below 7*btdc?
Or.
Just deal with the chuggy EGR....I hate it btw... which is worse for the motor...a vac leak created by a crappy modulator/EGR system
or a disable EGR...
Gurus' rule in please.
thanks
Matt
Or.
or a disable EGR...
thanks
Matt
