Balance is important!No excessive corrosion or rust issues - just the right amount apparently.
I bought my 06 new, and wouldn’t change a thing, but yes I do think VVTI on the 06-07 is overrated by people just comparing specs on paper. VVTI allows better “breathing” at high RPM, and how often is high RPM really useful in a 3-ton full time 4wd vehicle? I personally think that the 03-07 5-spd is more interesting/useful for its lower first gear.
If desired the power difference can be mitigated by using the 06+ variable length intake and a set of headers (which are much less costly than the 06+ versions with SAIS, which is another problem waiting to happen). The 5 speed was the biggest improvement Toyota made to the 100 series.
I think this is what was meant by:Wow, I am looking at a 2006 model and below is the inspection report from Lexus.
This is too much right, especially the traction sensor warning?
My mechanic said the oil pan gasket alone would take 17 hours to complete.
I now appreciate mine more with all the updates
The devil you know vs the one you don't or something like that
came here to say this. also, i really do not understand all the hype of the 06-07. from my understanding vvti makes the 2uzfe an interference engine, not to mention the exorbitant cost increase required to replace the cam seals on the vvti (assuming a shop does it). at least in 98-05 if your timing belt breaks you wont tank your engine.The devil you know vs the one you don't or something like that
06-07 has the nicest looking front grill of any year LX imo. For me that is enough to go with the newer model.came here to say this. also, i really do not understand all the hype of the 06-07. from my understanding vvti makes the 2uzfe an interference engine, not to mention the exorbitant cost increase required to replace the cam seals on the vvti (assuming a shop does it). at least in 98-05 if your timing belt breaks you wont tank your engine.
i always keep an eye on 100's for sale in my area and i specifically exclude 06-07. why pay a premium for something that has a higher cost of ownership for no added benefits. some ppl buy them for the tail lights, but you can add those tail lights to any 100. I do appreciate the 5th gear on the later models, but you get that starting in 03.
