Hi all... Due to lots of changes we need to get the front drive shaft lower...
The idea i had was to put the read Diff ( the hole things pinion, king, arbs... the hole metal casing ( don't know how it is said)) in front, cause the rear has a lower mounted pinion, which will be a fix to our problem.
Can it be just changed , swapped , bolts on the same place...???
PS: Both of the diffs are 4.88 with ARBs.
