Cam,
Is your rig street legal? I (only) have 33/12.5s on 8s and I get grief at safety inspection every year for the tires sticking out a bit beyond the fenders. Just curious if I'm the only one. Sorry for the hijack.
Here's a pic of my fat a$$ 38 in tsl super swampers. There almost dead. Next ones will be just a wee bit narrower.- Matt
give me a day and i'll take a couple poser pics. All my pics are from wheelin and none of them are very straight on.
Actually a narrower tire typically gives a better contact patch for most wheeling..
For mostly wheeling I would think the wider the better as long as you have power steering and enough clearance. You are just going to have a big ass spare that's all!
Weight of the vehicle is a big factor in how wide you need also.
are yours bias or radial?
thanks
bias
a friend ran 37 radials on his ZJ, they were definatly more square.
Why?
So a truck that weighs more will put more pressure on the contact patch. Yes that is true. But a skinnier tire will actually have a longer (and larger) contact patch than a wide one will.Pressure on your contact patch.
So even though a heavier rig puts more pressure on the patch, the skinniertire will actually have a larger patch. The skinnier tire increases traction.
Weight does not really matter until you get into flotation situations. Then there is no way you can tell me that a suburban on 44's will do better in the sand than a 1500 lb buggy on 44's..
The more your truck weighs the harder it is to make it perform off road.
Yes, obviously there will be limitations to this but yes.. Additionally, the longer contact patch is harder to break loose than a wider patch..
In flotation situations you have two basic choices and a multitude of driving styles. Skinny tire (lots of traction, cuts down to a "hard" surface) Wide tire that can basically be a floatation device. But if you get into the flotation situation, you better have enough HP to spin the crap out of the tires..
