TIRES how wide can you go on a stock 100?
Granite Bay, CA
You will need spacers on the front unless the wheel has an offset. Are they toyota wheels? How many miles on the tires? Search for posts by wngrog and his build up. He had the wide nitto terra grapplers on his with stock 18's.
So Cal/Montana
Website
www.crowncycleco.com
they are the Pro Comp Xtreme A/T 33x13.5 on Pro Comp 7089 rims 18"x9" with 4.75" offset and have less than 200 miles on them.
they were on a truck my brother in law had that he sold. all I have to do is go & pick them up
e9999
Gotta get outta here...
Moderator
US
doesn't the 100 require more backspacing than that (from memory) if you meant backspacing? If you really meant offset that seems like a lot.
hoser
Bay Area, CA
It is quite possible the tires will fit but definitely not with that wheel offset.
Granite Bay, CA
sorry I meant Backspacing
You should check or at least calculate offset for that wheel. Stock wheels are +60 offset and ideally you would want +30 or less for that width tire to clear the knuckle. With 13.5 width and that offset though, you'll probably still rub the inside back of the front fender well while turning. Some have actually just modified that inside bubble where it hits.
So Cal/Montana
Website
luckily he is coming down in a few weeks and he is going to bring them along with a set of 18" tundra wheels/tires he just took off his new truck in leu of some bling wheels
then we're going to play mix & match and see what we can come up with.
