Tires and Approved Rim Width
Winnipeg, Manitoba
Tire and rim question here if anyone has some time to answer. IYHO would it be detrimental to go against the tire manufacturer's approved rim width for a specific tire size?
Example 1: I have 265/70/16 ice tires that I would like to mount on 6" wide steel wheels(that I have yet to purchase) for winter. They are currently on 8" wide rims that I don't want to run in the winter. Most manufacturer's approved rim width for this size of tire is 7-9". In my ignorance, I'm not sure if I should mount these tires on 6" rims.
Here is another example if you don't mind. 235/85/16's are all approved by tire manufacturer's to be mounted on 6-7" wide rims. I would like to mount them on 8" wide rims for summer.
Any advice/opinions/help will be appreciated.
Marc
the 235's won't work on a 8 inch wide rim. The tires are only 9.5 inches in width. So the sides will be super flat and you might pop a bead off easy.
The 265 might work on the 6 inch rim. But guys who run 255's on the 6 inch rims find a lot of strange wear on the tires. The centre section wears quickly.
Thanks brownbear, considering this I think I'll move up from the 235s to a 285/75/16 for the 8" rim. Hopefully fuel mileage won't be compromised too much being that 285s are 2 inches wider and somewhat heavier.
As for the 265s maybe I can sell them or trade for a set of winter/ice 235s that would fit nicely on a 6" wide rim. Its proving difficult to find a properly backspaced economical 16x7" steel rim for a 70 series.
Take care
Marc
if you pm greg_b he has listed 16x7 rims you can use. Part number and all.
I run 16x6 toyota rims. Which guys are saying on here that with 255's they wear funny.
