Tire size speedo correction without gps. Using the calculator so I can program the yellow box.
U.S And Metric Tire Size Information Calculator
The calculator allows you to fudge the numbers on metric tire size value input until you arrive at actual tire size as published in inches. Going from stock Michelin M+S tires (31.3") to Toyo mt (34.9") with stock gears should result in speedo correction of 11.6%. Sound about right?
