Sounds like I should go35'sor 37’s.
How can I calculate how that translates into the actual tire size?
Don't forget that 35's is about the largest you can go on Stock Gears... so they say.
I was thinking 42’s now that 37’s are basically stock size.
We all know that 37’s are way too small. It’s just a matter of knowing what you want to do about it.
I guess if i was sticking to stock gears, a narrow 35 would be the best option. Otherwise, adult up to some real rubber and gears. My .02
There are guys who run stock gears and 37’s but lower gears in the t-case.Any plan to stick to stock gearing is doomed to failure unless your mods are aesthetic only.
Crawl gearing is as important as lockers.
I’m sticking to 37’s. The reason 37’s are too small is 80’s are too big. It’s good to design natural limiters in the system or you’ll end up killing it...or just being so overbuilt that regular trails are no longer fun.
Radius arms and 37’s crush parking lot speed bumps. It’s awesome.
Iam personally a fan of gears, lots of it. Went 4.88’s, but should have gone 5.29’s for the impending 37’s. Ill try to stay 35’s, but i know it wont last.
4Ds!!!!! Or 37s minimum, if OP has enough $$$ to get stage 3 it would be a great shame to get 35 or smaller.
35s are for people with less cahonas like me.....well I have my cahonas still but after being married with children they are only there for decoration and identification purposes.![]()
Agree, this is a tough question. I have been tinkling with my suspension, tire sizes for years now and you won't find a straight answer for it. Take it out on the trail, flex it out and if it rubs, start trimming or adjust your suspension.... It takes time.To the OP's request for info... Stay away from 33s.
All joking aside, you've sunk the coin into a lift and wheels which are sending you directly down the path to 37s and associated gearing (tcase at a minimum, diffs more likely). Will they rub? Maybe - depends whose tires you buy and how hard you plan on wheeling it.
Time for you to find a local club and turn your relevant questions into some conversations.
