Hi all,
I recently did the 85 minitruck disc brake swap on a 1968 fj40. Ever since this the steering has been really sloppy and loose and when flat towing the vehicle the tires will take a hard right and then lock that way opposite the direction the of tow rig and it almost looks like the tire is leaning on the ball joint. Meaning it uses the ball joint as a pivot point and the top of the tire leans away from the truck and the lower side tries to go under the axle housing . Could this be due to incorrect shims and bearing pre load or is there something really really wrong here.
