tire options on 9 in rims?
new jersey
was looking at a deal for 9 inch rims for a 99 lx; does that give me more options with larger size tires? if so any recommendations?
Darren , can you check your figures ... You are representing the 305 and 315's as 33 and 35" tires respectively , however they might not be .
(315mm*0.0393701 inch/mm*60%)*2 + 18 = 32.9 "
(305mm*0.0393701 inch/mm*60%)*2 + 18 = 32.4 "
You may have been thinking of 315 75's and 305 75's .. R16 . Or perhaps I'm missing something ....
:cheers:
TY
sorry i am a newbie with this stuff but here is what i have a stock 99 lx 470 which currently has 18 x 8 in rims; the deal is for 18 x 9 inch rims for $350 now by just going to a 9 inch rims will that enable me to get bigger tires or it simply does not matter? the rims are 40 mm offset i do understand that this may affect the bumpsteer and maybe the bearings but i am not really worried about that part thanks also someone told me that 325/65/18 would not fit on a 8 inch rims so that is why i was thinking of getting the 9 inch rims so they would fit. am i wrong?
Thats more of a 35" tire you mention there .. 325/65R18 . Many of us 80 guys run 35" tires on the stock 8" wheels , so I'm not sure there would be a problem . However , go to a tire site .. look at the manufacturers recommendations for wheel width with this particular tire . You'll find as tire widths get larger , that the recommended wheel width does as well .
I bet the 325/65R18 is close to 13" wide .
As far as fitment on your vehicle .. I haven't a clue .
TY
the tire manuf will usually tell you what size rims are acceptable for what tires, although one can usually stretch things a bit.
Keep in mind that if you want to take the rig offroad you might be better off getting a 17" than a 18" (more rubber between the rim and the rocks... and also much more choice in aftermarket wheels such as steelies)
E
thanks for the responses i agrre with the idea of more rubber is better especially because we do lots of beach stuff and airing down helps with more side wall thanks again
and if you do a lot of airing down, you might be better off with a narrower rather than a wider rim, for improved retention?
E
