Tire Chains... Mud,Snow & Storage
North Front Range, CO
Went to buy some tire chains for my 285x75x16 tires.
They had hwy and mud chains. The sales man said the hwy chains will brake if I use them in mud/rocks.
The mud chains are extra heavy duty (and heavy:crybaby: )BUT no V-bar or spikes. Its just a chain cross bar.
On our semi's we run 1/4" spiked chains.
The store could order a pair of spiked chains for $320 a pair OR I could cut down a semi chain for $270 pair.
I will wheel in the Colorado. The trails are steep with ice/packed snow or greasy mud this time of year.
Will the heavy duty chain cross bar work fine OR should I hold out and find some V-bar or spiked chanis?
Where is a good place to store the chains on an 80 where they are out of the way?
This is the chain we use at work on our semi's.
I have only seriously wheeled twice with chains on. Once in over your head snow depth and once on a snow/mud mix. Nobody had specific offroad or 'mud' type chains and a couple had cable chains clearly designed specifically for highway use - including me. Yet nobody broke any chain components on either trip and these were essentially the same trucks/drivers on both trips.
So it seems to me that the ones pictured are going to last well offroad. As you likely know, with chains it seems the factor for success is proper installation and maintaining proper tension and positioning of the chains.
So, I vote your chain choice is fine.
DougM
The MUD chain is $90 /par with no studs. Thats about the price I want to spend on chains.
I don't want to spend $300 for a pair of chains (see pic).
Just woundering if a Vbar or stud chain will do much more better than a standard chain?
I haven't wheeled with chains yet, so my info might be worth ignoring...but here goes FWIW... I talked to the guys at tirechains.com and they recommended the heaviest guage chains available as the most suitable for "mud chains." V-bar, studs, good for on-road, but as heavy as possible was what they think you need for off-road. Of course, installing them as tight as possible is also critical.
The delivery guy almost had a hernia...they are really heavy...
I just picked some straight bar chains up today, I was going to use terchains.com but with shipping it wasn't any savings from calling my local Napa guy (craig at northcreek napa in bothell WA) and had him order me some, straight chain and heavy as hell but 106 per set plus 12 for tensioners and no shipping. I am moving Back home and Driving out of Seattle on saturday morning, hopefully Snoqualmie pass wont be that bad but you never know, Hence the chains will be riding with me.
Dave
Dunno what you have in your d/s rear panel box thingie, but thats where I keep mine, the p/s seems a little weak, but I keep a set (2) of chains, jumper cables, tool kit, jack, and some spare oil in the d/s box. If you want to use the little plastic box, you may be SOL for a good place to keep them, could be a spot under the hood???????
Also, if you use a bag, you could stick them on top of the spare (stock location)
but then you'd have to get out in the snow and lower the stupid thing. My vote is the rear box.
Dan
The v chains are really for ice.
What type of trails are you talking about? Forest Service roads that are probably 2wd when dry, or more technical stuff? Are you running all terrains, muds, or rock tires?
The standard cross bar chains should be more than enough to keep you moving forward, although in my experience AT's plus standard chains are not ideal for lateral traction because neither the tire nor the chain are designed for offroad lateral traction in extreme conditions. I've seen a good MT (just a siped old style BFG MT) handily outperform AT/chain combos on Spring Creek in moderate snow depth - are you are familiar with that trail? - and I was unfortunately the guy with the AT's and chains.
The heavy duty chains are a good idea, but I'd really look into something that will maximize lateral traction if you are running AT's. Of course, if you are running AT's I'd also ditch them for an excellent snow/mud MT and keep the chains only for emergency purposes.
I think we tend to have too much rock on most trails to make full time chains practical, especially when it gets steep, but you may be running deeper stuff than I see closer to the Front Range.
Nay
Another thing to consider is wheeling with chains is clearance. Your OME 2.5" lift and 285s might be fine without chains but with chains they will tear the crap out of your flares and body.
I prefer an AT tire when I'm using chains. Getting chains on an MT tire has proven to be impossible for me at times. The lugs catch the chain and don't allow them to get tight. Another thing is that to run chains effectively you need to run more tire pressure. This could hurt you traction wise on the trail. I've never used chains in rocks. Always dirt roads with medium to deep snow.
Another problem I've encountered is the tranny will get hot when pushing through deep snow with chains on. I think the added traction creates more heat in the tranny. A few years back I burned up a 2 month old Centerforce clutch in my V8j60 when I chained up. The power had to slip somewhere and since the wheels were getting traction it ended up at the clutch.
As far as storage, I use a 6 gallon pail. It will kill you if you try to lift it with all 4 chains in it. When I've had a rear tire carrier I've put one pair on the spare tire. This is especially nice when get done using them. The mess is outside the rig instead of inside. Even if they are clean they can cause some condensation problems for weeks later as they release their moisture. I always remove them from the vehicle as soon as as I get home.
Since I'm running 315s. I'm using cut down semi chains. They were free. Our neighbor has a trucking company and when they buy and sell trucks they pull the chains off of them so they end up with extras. They use cams to tighten them up so you need to have a bar along.
I just got a pair of V-bar jobs for mine. The sack said 305/70/16 and 285/75/16. They were a "deal" at 180 bucks for the pair....:eek:
They are very heavy and I have split them into two bags in order to move them around without rupturing a disc.
Nay,
I just moved to CO and have been wheeling in BLM north of Silt/Rifle.
I have Wild Country RVT (MUD) tires with over 55k mi in them so they are lacking some lugs. I have a new set of Xterrains but I want to get every last mile out the the RVT's ;) .
Don't know where Spring Creek is.
I cut wood above Rifle Gap St. Park.
The trail is some what steep in some places. Fine when dry BUT its a "slip and slide/bob slede track when wet or snow covered.
There is one place where I just about side swipe a tree every time I go over the dip and hump. I think chains would help this.
I have no lift, its OEM for me:D
When I fill the back up with wood (1/4 to 1/3 cord) the back drops down and I rub when I hit dips in the road.
Chains wouldn't work on the back but they would clear fine on the front as the front comes off the ground when if fill the back.
I ended up buying a pair of the hwy Vbar chains. They are DOT legal
I can order a pair of the studded mud chains for $270. Not DOT legal.
I might order or make a pair of the studded chains this spring.
The reason I want the studded chains is when the BLM trails get muddy, its like grease. If there is ruts in the trail (no lift) I slide right into them (no electric winch):crybaby:
I would thing that if I had 4 studded chains, I would have no problem with slidding into the ruts.
When I chain up my semi when going up steep muddy roads, I will get to a point where I start to spin on the loose road base. Once I dig dow the the rock road base, the chains will smoke the rock untill I cant go any more or I make it up the hill.
The truck I have only has one studded tire chain. The rest are normal chains.
I have a Kalifornia truck so it can only have singles on the outside tire as the inside is too close to the frame.
WHat brand are they?
Do they have cam to tighten them?
The bag says "Road Blazer" and they do have cams.
I'd take a pic but my wife is out of town and she took the digi with her...:rolleyes:
And let me guess, you timed it so they would arrive while she is out of town:D
No,
Actually she suggested I get them...;)
We both know that when something like that happens, a fast response is critical...:D
Oohh...this should start the debate about having way more traction on the front axle than the back, and the potential problems decending steep hills (will the rear want to come around, especially loaded with excess weight???).
You honestly sound like you just need a good set of mud/snow tires, but that's just my experience and YMMV. I've never found good muds to be lacking unless you are really bogging, which is tough to do in Colorado without looking for it. Lockers help immensely.
Nay
Here's a few responses from an old thread on the subject...
turbocruiser said:
Diamond chains also help more for turning than ladder style chains. They tend to hold the tire better too. Cable chains SUCK, I repeat SUCK, I had a set for my 4Runner which snapped within ten miles of putting them on. They tangled around my mudflaps and running boards and ripped everything all to hell. IMO the best 4x4 chains are RUD Grip 4x4 which Bill Burke sells. Goto www.bb4wa.com and get a good set. Ohh, 4 tires always equals 4 chains, any other way will result in problems. If you only have two chains though, I'd put them on the front axle cause then you have steering braking and accleration. HTH. Ohh, BTW, the RUD chains are low profile so no rubbing worries. HTH. :cheers:
turbocruiser said:
I looked up my part number for my RUD GRIP 4x4 chains and they are part number "2532". These are the largest tire chains RUD makes. There are also some ranges on the tag which include 33/12.50R 16.5 and 285/60R 18. I suppose my 285/75R 16's are in the middle???
Some things to point out about these chains. First, they are an alloy link. I too saw several styles from several other manufacturers that were diamond link but they were made with a mild steel. These chains have an extremely strong alloy steel that includes tungsten to allow them to last long time even on exposed asphalt. Another thing is that they are square link which is what allows them to "bite" more than a round link chain. Another thing is totally welded links - most good chains come with welded links nowadays but the welds on these links are really awesome with really good penetration, not just a surface spot weld that when worn down allows the link to open. The links themselves are only 5mm which is what allows for the low clearance classification. The chains are reversible so they last even longer in that you can reverse them so that if one face is worn, you can allow the other face to take the wear. The chains are easily able to install WITHOUT moving the vehicle over them. I have personally put them on several times when I was stuck in super deep snow and I did not have to move the vehicle at all. All in all a superior chain in my opinion.
Ohh, forgot to mention they are TUV certified which is an Austrian/German certification as well as ISO certified. They come with convenient ballistic nylon carrying case. Hope that helps, and sorry for the long delay, I was not paying attention at all apparently. DOH! :cheers:
Here's that old thread: https://forum.ih8mud.com/showthread.php?t=52101&highlight="tire+chains"
Consider that a good samaritan search giveaway! :flipoff2: :D :flipoff2:
Ohh, another good old thread: https://forum.ih8mud.com/showthread.php?t=28568&highlight="tire+chains"
:cheers: :cheers: :cheers:
