Tire carrier with stock bumper build
Content may include affiliate links. Please see terms for details.
Boise, Id
Well I have not been on here for a bit. Check in from time to time checking out the great stuff. I built this for a friend of mine and thought I would share to give some guys ideas. He wanted to retain factory look. I used .188 wall 2x2 for the main swing and .120 for the upper frame. 2x4 .188 for the spindle support, and plated the frame. Built the hitch into the factory frame with additional plating and support. Also did a front frame mounted receiver that comes out the factory bumper but forgot pics. He needed to be able to run winch front or back. :steer:
Boise, Id
More pics
Vancouver BC
the first pic is gold. Thanks. I especially like how you marked the contour of the bumper corner.
Cincinnati, OH
Agreed. Looks awesome. Very nice attention to detail on contours and the side angle of the tire to the rear hatch.
Flank
American by Birth, Texan by the grace of God.
Flower Mound, TX
Website
www.staltimber.com
First of all, looks very stout! Matches the lines in the back of what I did a while back, but you may want to watch your spacing from the back hatch to avoid a broken window if you get backed into a tree / rock.
I love it! Does anyone sell a bolt on version of this?
I used to, but found it too time consuming. Josh at AJIK asked to be able to build on my initial design and he beefed it up a bit, don't know if he is still selling them or not.
https://forum.ih8mud.com/80-series-tech/318750-bolt-tire-carrier-finished-now.html
Just for the record, I am not building these anymore. I loved it when I had it, it was stout as hell and held up on the trail, but I used my own truck for a jig. Now, I've cut off my cross member and installed a 4x4 Labs that I welded from their kit.
Topton Pa
Looks great! Since I have no spare tire or holder, this could be a great solution for me. I even have some 2" square stock laying around.
Boise, Id
Thanks all, the clearance to the gate is 2". Should not be a problem. Unless the rock or tree does jump out. Years ago I was backing in very deep snow getting turned around and a tree jumped out caving in the rear gate of a heep I had. My own set up is 1.5" with a 37" tire. I built this set up over 3 years ago. To be honest I'm surprised I have not had a single problem with my own set up. It has truly been put to the test. Thousands of miles of washboard and two track roads still going strong.
Thanks again, Phil
