I bit the bullet and corrected it this evening. It only cost me 45 minutes. I don’t have fancy tools, so I need the markings. Also, the belt markings are off 1.5-2 teeth when installed backwards. I’m thinking to compensate for any stretch of the belt? I can’t imagine the belt would stretch though.
Also, the belt markings "are" off 1.5-2 teeth when installed backwards. I’m thinking to compensate for any stretch of the belt?
You did not stretch the belt. I assume you meant "were" not "are"
The Toyota belt and Aisin kit belt marks. Always line up perfectly, with the 3 hard marks. But not always will the crank pulley mark, lined up with plastic #1 timing cover mark Which is one of the reasons, I use hard mark on crank sprocket, lined up with oil pump housing hard mark. I also test for proper timing, with hard marks. Before installing #1 plastic cover.
Looking at your picture, which is obviously before spinning crank to test. Its crank sprocket to belt marks, "should" be dead on as I pictured in above post #11 for you. But I can't see that with No. 1 belt cover on. So can't see if your off a tooth or not. The test is spinning crankshaft clockwise, 720 degrees. At which point, the 3 hard marks line back up. But the belt marks will not line up again, once crank turned 720 degrees. So you've not tested bases on your last picture. But you look okay.
I don't see the Timing belt cover spacer ("mouse door") or its gasket in. Make sure to install these, before install fan bracket.
If you did not seal ((precoated parts, (yellow circles)) threads of tensioner pulley (No. 1 Timing belt idler sub-assembly) bolt. You will have an oil leak. We also sometimes get and oil leak. If idler (No. 2 Timing belt idler sub-assembly) bolt not sealed. No 2 threads should not leak oil. But if oil pump has ever been removed, it may.
Make very sure, the wire loom housing the crank sensor and oil pressure sending unit wires. Is tucked behind fan bracket, before installing fan bracket.
This wire loom, is routed
wrong in below picture. Wire housing loom should be routed behind fan bracket.
If routed wrong, as seen in above picture. Very high risk of cutting wires on serpentine (drive) belt.
