What is wrong with the use of wire nuts? They are made to join wires, yes? I have had good results in the past. In my experience if you see electrical tape used on wire nuts they were not installed properly.
It may not be a boat, but you'll find marine grade wiring easier to solder, has more strands, is more pliable than standard primary wire, plus it won't corrode when exposed to moisture, which can lead to a substantial voltage loss across a circuit. That voltage drop increases the load on the circuit which equals heat.
Murf, check out the TSB's regarding wiring repairs and you'll see Toyota generally recommends soldering circuits when they need to be repaired.
Kevin, I'm surprised you aren't advocating just using wire nuts and solid wire as a "good enough solution" with a few wraps of electrical tape for good measure. What's your point of reference where crimped connections have proven themselves superior to soldiered connections in an automotive environment? Yes, most vehicles have thousands of crimped connections, but those connections are housed in a plug of some sort so tensile strength and vibration aren't really an issue.
In fact will take apart factory harnesses to get the wire. Prefer to make it look as factory as possible, use correct wire type, color codes, methods, etc, as often as possible. On the project that we are doing, all of the battery feeds are white, grounds are BRN-x, IGN switched feeds are BLK-BLU, etc. As often as possible, use a factory crimped connector on at least one end. As of now, have not used one inch of aftermarket wire.
They also know how to make it all look clean and neat without that rats nest look.
... I wish they never made the "quick splice" hack connectors
Good advise - ask to see the installers work.
If I had a nickel for ridiculous rats nests of wiring debacles weve seen..........
Its the first place we look when there is an "electrical issue" with a vehicle - good example of poor wiring = headache. I wish they never made the "quick splice" hack connectors
Oh yeah "suitcase" connectors. Pretty sure these ARE the devil... they even come in red
TORTUS said:If you have the means, I highly recommend one of these.
