Tie Rod Rubbing On Control Arms (1 Viewer)
TOY350
#1 Super Guy
Grants Pass, OR
Just like it says, my tie rod is rubbing my control arms. I have J springs, no spacers and Landtank's caster correction plates up front. Perfect caster. When I brought this up before the solution given was "grind your control arms for clearance" which I haven't done and not too sure I want to. How many other people are experiencing this and has there been any other solutions thus far?
e9999
Gotta get outta here...
Moderator
US
yup, bit of a crapshoot, some need it, others don't. But it starts appearing at around 2.5" lift or so. Seems like the only obvious solution is grinding it. I don't like that. (It's apparently pretty hard stuff too.)
TOY350
#1 Super Guy
Grants Pass, OR
Cruiserdrew
On the way there
Sacramento, CA
With a moderate lift, it may be enough to just grind down the casting ridge.
I took about 1/8 inch total, and need to go back and take a bit more.
e9999
Moderator
US
I have to say that I never read of a ground one breaking in 2 there, so these things must be amply strong.
TOY350
#1 Super Guy
Grants Pass, OR
I haven't either but just the though of a control arm breaking is what has me nervous, I pack the family in and hit highway speeds with this. I could see checking for stress cracks on a daily basis just to ease my paranoia. :)
So it sounds like nobody is grinding through the whole thick upper section then, which I was hoping was not the case.
sleeoffroad
Supporting Vendor
Website
www.sleeoffroad.com
I thought it doesn't happen with Landtanks plates? :D
Seriously, just grind them. Taking an 1/8" of the arm on the casting ridge is going to do very little to the strength of those arms. Or you could buy our arms, then you won't have that problem :D
e9999
Moderator
US
maybe one could futz around with the TREs, raising them up a bit with a spacer or something...? Or use a longer tie rod with a couple of kinks in it?
Phoenix
Website
www.tralaz.org
Neither of those ideas sounds good to me. The tie rods attach with a tapered fit, so you can't use spacers there. Bending the tie rod is creating weak points.
There is one other option, to get rid of the tie rod behind the axle and put it in front, I believe there's a kit floating around somewhere. Not cheap.
-Spike
Yep I never brought it up but I also had to grind my control arms with LandTank's plates. Not a big deal but the control arms are made of some very strong steel and worn down my 4.5" disk more than I would have expected.
Remember also that the rod will rub the arms MORE on the edges under flex, so take off more around the edges. Also when you jack it up with the tires off, turn the steering stop to stop to accuratly mark where the rod rubs the arms.
North Cadillac
Mine were touching with slee's plates. I had a bit too much caster IMHO for my lift height but it sure tracked well. That metal is real tuff and i had to grind for a while to get it right. I'll post some pics when i get home as they are on my home PC.
TOY350
#1 Super Guy
Grants Pass, OR
Thanks Concrete. Bear could you post a pic too? I wouldn't mind seeing a few these before I take out the grinder.
Now Christo, how much for the other 3 inches of lift I need so I can run your arms instead? :)
e9999
Moderator
US
snip
-Spike
both easy to overcome with minimal fabbing but probably a moot point if the arms are still plenty strong when ground
Cruiserdrew
On the way there
Sacramento, CA
Really?
That's a pretty bold statement. I want to see you do it and not end up on the scary steering website.
North Cadillac
here are a couple of pics as promised. :hillbilly:
I ended up taking just a bit more off then that last picture shows.
landtank
Supporting Vendor
Groveland MA
Website
landtankproducts.com
I think the rubbing with my plates is in a different area than that of Slee's. If you look at toy350's pic the rubbing on the arm is where you would first have to turn the wheel some. As you turn the wheel the rod moves down along the arm so it won't be up where CJ's pic shows but closer to the axle.
