tie rod ends
Edmond, OK
Does anyone know a trick to get the tie rod end off the "tie rod". I got one side off and can't loosen the otherside. I've been spraying pb blaster on for days and then hammering the end to try to loosen so I can remove. The others came off fairly easy. Any ideas appreciated.
Thanks,
Brian
I was having some problems taking mine off just yesterday. All I did was spray a little WD40 in the slit on the tire rod to start. I then took a long 3/8 extension (like 18") and inserted it into the eye hole. Then I took a pipe wrench to the tie rod for grip. At first, it would go anywhere. But after a while with a little twisting and once it broke loose it came out pretty easy.
I was thinking about heating it, but no fire available at the time.
Hope this helps, Mike
