I'm in Baja Mexico specifically, and don't plan on returning to the states for at least several months. Vehicle is an '84 HJ60.
My driver's side tie rod end has a bit of play in it. If I give the driver's wheel a good shake I can feel it move and there's a bit of click. The passenger side feels solid. I can feel the play/clicking telegraphed through the tie rod if I hold it while someone shakes the wheel.
I don't feel it while driving (but the roads are all pretty bad down here. I noticed it after a mechanic pointed it out while replacing a busted birf.
The mechanic said the problem is the driver's side (left-hand) "terminus" (i.e. ball joint). The downside is lack of parts availability. His supplier didn't have one. I stopped at a couple of alignment shops and they just looked at it and shook their heads and told me they couldn't get parts.
I thought perhaps I could grease it and tighten the castle nut to get some more life out of it but there are no grease fittings and I couldn't get the thing off with a sledge & a bottle jack. Castle nut is already as tight as it's going to get.
So I'm going to have to find a shop to do the labor and track down the part.
Questions:
1) Is there anything else in the steering linkage/knuckle/axle that could be causing play? I just had both birfields replaced with chromoly hardened ones but only the driver's side has play in it. Probably not related.
2) Assuming it's the ball joint, how is it going to fail? Gradually and gently over many thousands of miles? I'm driving on rough roads & trails. The ball joints have 20-30k on them. I believe they are the 555 units.
3) Any options for improving the situation short of replacement?
4) Any suggestions on finding one in Mexico? I believe I'm looking for Toyota part #45047-69065. Was it used on any other Toyotas? The early 80s solid axle pickups are pretty common down here.
Many thanks.
Questions:
Many thanks.
