Throttle linkage clips around ball joint broken
Missoula, MT
I was recently stranded when I turned a corner and my throttle stuck, causing the engine to rev up to 4000 rpm. I shut it down before any damage was done but once I towed it home, I found a 3" shaft 3/8" diameter connecting the two levers off the throttle linkage had a broken clip to hold in the ball joint. Does anyone know where that full shaft assembly can be purchased, or if the clips themselves are available for replacement? I saw a few other posts about problems with engine rpm climbing quickly so I'll pass this along to those threads too in case this was an issue for them, but any help on locating the part would be appreciated (pic attached).
Missoula, MT
Local dealer can order, 78197-10010
I went to a few different local shops (I didn't see your part number before I went in), and they couldn't seem to locate anything that worked. I'll try them again with the part number, thanks for sending that but what they looked up they said had been discontinued. I'll let you know how it goes, thanks again.
rkymtnflyfisher
Trout Bum
Montana
I might have a couple down in Stevi.
73FJ40
After another night of rust removal!
Western Massachusetts
Rod Clamp - Toyota (78197-10010) $2.10 list.​
Some dealers don't want to take the time to order small parts, so, "DISCONTINUED."
3_puppies
Helena MT
slim options around MT, usually only 1 dealer in each large town.
mattressking
10 digits to freedom
Idaho
Not sure your junkyard selection nearby but late 70s/early 80s toyotas use them. I pick bits like that off as spares when I see them. Pickups are usually a fun scavenge for bolts and hardware. Otherwise order online through one of the many dealers online? Doesn't take long usually.
rkymtnflyfisher
Trout Bum
Montana
Still need these? Sorry, I just caught back up with this thread.
I'll be up at the paddleheads game tomorrow evening.
