Using the same part number as Travis', I've just bought a set 2 weeks ago, mine costed a bit more. Basically, just walked in a Ford part counter (the 1st time in ever!) and gave the dude the number and he was able to order them, much easier than spending time in junk yard.
Same here. Just make sure that when you write down that part number the 5 in the first part look slike a 5 and not a 3... : . If not, your gonna find a couple of parts that are like $50 each...
is there any fabrication that goes along with switching to ford towers? I am in the process of doing a scout p/s conversion and have elected to go this route. (thanks to woody and his abundant knowledge)
fab, not really....worst part is drilling out/pounding free the factory rivits to get the stock tower free. My towers are only bolted in place right now, welding is on the list however...IMO, if you don't jump your rig, they will survive bolted...if you like to leave the ground, then definitely weld. I do check my bolts tho frequently, and have found them loose once.
(two bolts to install, IIRC, you can redrill one of the stock holes for installation...)
I know what you mean. I was fighting with the rivits on my stock steering box last night! its a good stress reliever when you get to pound the sh*# out of something!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
