Seems like it’s all EG or PG based. Just that the OAT has organic acid, less than 5%. I think the goo problem occurs with the true dexcool antifreeze and with running coolant low, air in system, probably many other factors too. I’m almost convinced I would have probably been ok, but I had it flushed anyway and the older formulation green EG put in it. Will continue to watch it.
On a side note, what does your rad pitcock look like? Mine was stripped and leaking and they had a hard time matching it. All the ones from the Napa’s and such had an o ring at the end and different threads. Mine had a rubber washer up by the head and 12 x 1.25 threads.
