2003 LX470 for $15.9 129k miles. Been on the lot for awhile.
I looked at the service record and some things that popped up were:
GOOD:
-Timing belt done at 102K but nothing about water pump or anything else that would be done with it
-regular oil changes up to 60K then records for only 2 oil changes after that
- brake booster replaced - don’t other brake components need to be replaced if booster is?
- 3 flushes of the transmission, diffs and transfer case
- 3 flushes of the brakes but the last flush they said fluid was black. Seems odd given it was flushed a couple times previously and booster was replaced. May mean brake components are deteriorating
- power steering flushed once. Is this part of the AHC?
- coolant flushed
- lived in Tucson
BAD:
- service inspections showed rack bushings shot, but no repair
- service inspections showed rack and pinion leaking need replacing but no repair
- service inspection showed cv boots deformed and grease leaking, but no repair
- AHC wasn’t specifically serviced, unless when a power steering flush is done that includes the
- Brake booster replaced, but brake fluid black after multiple flushes over its lifetime, is there more brake work to be done in its future
- timing belt done but no mention of water pump, tensioner or anything else
- brakes replaced several times while turning rotors, rotors never replaced so that will probably be due
- bearings never serviced
- it’s a Lexus (seriously)
What do you think? Value should be 10K? 12?
I might have time to look at it tomorrow.
GOOD:
- coolant flushed
- lived in Tucson
BAD:
