This high steer arm and pitman look OK?? (1 Viewer)
Nebraska
Here is what I am running. The only reason I ask is because the steering box stops before the bump stops in both directions.
typically, a 7" pitman is needed. Sounds like your pitman arm is too short. Sorry. You can run a heep pitman arm. They are nearly flat, with about 1/2' of drop. Look on old cherokees and wagoneers for one.
cheers-
Dustin
Las Vegas, NV
You might wanna check the clearanceat those u bolt plates .. looks like the might conntact when trying to turn....
