Things to do or not before smog test?
Discussion in '80-Series Tech' started by e9999, Jul 17, 2005.
  1. e9999
    e9999 You want to do what...? Moderator
    16,737
    592
    Sep 21, 2003
    US
    OK, here comes another required CA smog test.
    Passed just fine a bit over a year ago, but I'd rather not have to deal with problems and have to go back... Plus this may give me the necessary motivation / excuse to do something worth doing on the truck...
    Anything I should or should not do before taking the test?
    I have replaced the plugs recently, the plug wires test fine, and I will probably put in a new rotor and cap by then. Also replaced PCV and air filter.
    I was thinking of running a couple of Techron injector cleaner bottles in the gas for a few weeks taking the test. That should not hurt.
    I have also been thinking for a while about doing the "Suck Seafoam in the intake" trick but I'm wondering if that's a good idea to do it now given that that would likely dissolve and make a bunch of gunk flow around. Waddaya think? OTOH, it might clean things up a tad.
    Taking the intake off and cleaning the inside seems way overkill, no?
    (Only 78k or so)
  2. offroadkid
    offroadkid
    979
    Albums:
    1
    42
    Oct 22, 2003
    El Dorado Hills, Ca.
  3. e9999
    16,737
    592
    Sep 21, 2003
    US
    I'm surprised. Not sure how the oil cleanliness would be reflected in what is reinjected by the PCV... Maybe more fumes?
    I do remember reading here that somebody noticed a temporary improvement in smoothness with cleaner in the gas... maybe not a bad thing if there is some left in the gas during the test?
  4. Lars
    Lars
    658
    1
    Apr 17, 2003
    I've always heard new oil and clean air filter helps.
  5. Hants
    Hants
    439
    Feb 16, 2004
    Behind the bar
    Replace the gas cap. Mine passed inspection, but the tech cleaned/wiped/inspected it for a long time (many 10's of seconds) before he put it on the machine.
    Several weeks later I discovered it was leaking fuel -- now I wonder how it passed the pressure test at all.
    Also, I've heard that if you've recently had the CEL light reset (fixed the underlying problem or not) or disconnected the battery, they can/will fail you for insufficient data.
    I'd be leery of additives or wild-n-crazy cleaning exercizes within a tank or two of testing.
    May you pass the first time! :beer:
  6. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    679
    Dec 13, 2002
    Knee deep in hookers and gin
    If you have an OBDII truck (96+) you will need to have all of your monitors enabled to pass. You can't just reset your light.
    I fast idle mine while waiting in line. I see people fail because the cats get cold while they are waiting. I run 1500+ RPM to get it nice and hot.
  7. e9999
    16,737
    592
    Sep 21, 2003
    US
    so clearing up all the codes even if no CEL is not a good idea then -assuming I could even do that-?
    any point in putting premium in for the test?
  8. Brentbba
    Brentbba Former Golfer SILVER Star
    10,303
    1,208
    Mar 27, 2003
    OC, CA
    Just go and don't worry about it. hehehe :flipoff2:
  9. elmariachi
    elmariachi
    1,977
    23
    Jan 4, 2005
    Shufflin' Through the Texas Sand
    In Texas, the inspection station computer can tell if you reset the codes in the last 300 miles. Likely the same in other states, considering that everything we have here our legislators learned or stole elsewhere.
  10. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    Ditto.
    :D
    I've never had a problem with any of my 80s passing smog. The one I sold 4 years ago (1994 model year) passed with flying colors -- I had done nothing to it aside from a tune up a couple months prior to selling it.
    My assumption going into these tests is that if the rig is running well, I won't have a problem. If it's running rough, fix the problem before taking it in. Maybe I'm just spoiled with Toyotas (and hondas).
  11. Darwood
    Darwood
    1,957
    9
    Oct 8, 2003
    Z.O.W.I.E. Headquarters
    I'm not sure if OBD-II even holds that detailed of information. I'm about ready to call BS on this but I need to do some research first. ;)
    Of course you all realize this just gives the pre-95 guys more room to talk.
  12. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    Not in GA on a friends late 90's Chevy blazer, it that case you can clear the codes with a scanner in the parking lot 50’ away and as long as it does not set the code again it will not fail, but if you clear the codes by disconnecting the battery then it will have to go through a "drive cycle" (whatever that is for that vehicle) before it will pass. for Chevy I think a drive cycle was one warm up & one cool down. nto sure waht it is for an 80.
    No tail pipe sniffing in GA for 96 on, making the post 96 superior here.
  13. Darwood
    Darwood
    1,957
    9
    Oct 8, 2003
    As far as I could tell by my research, OBD-II only sets "readiness flags" after a certain drive cycle which tend to involve 30 mph driving and 55 mph driving. Other than that, it seems OBD-II doesn't seem to store information other than thrown codes.
