Ok, so, long story short, my fuel pump is leaking a lot of oil (possibly some fuel as well, but the oil makes that hard to tell), the carb bowl doesn't even fill to the bottom of the window (even after giving everything I could reach through the top of the carb a thorough cleaning), and there is essentially no fuel in the hard line to the carb after running.
So, I'm planning to just replace the pump (with OEM-quality), gaskets, and filter, and see where that gets me. Worst case scenario, I've replaced a 27-year-old component that was leaking oil and it's somethng else causing the lack of fuel delivery.
However, I haven't ever done anything with a mechanical pump before, so I have some ridiculously basic questions.
1. How much oil should I expect to have to catch? I don't have a clear idea of how high the fuel pump is relative to the sump, so I don't know if I need a jug and a funnel, or just some rags.
2. How much fuel am I going to have to deal with with from the lines/old pump/filter? Is there a trick to not getting it all over the place?
3. Do I have to prime/prefill the new filter/pump/etc., or can I just hook it up, pull the choke, and let my battery/starter/fuel in the bowl purge the air from the system?
