Thermostat Replacement
Discussion in '40- & 55-Series Tech' started by Steel, Mar 26, 2004.
  1. Steel
    Steel
    162
    Jul 15, 2003
    Long Island, NY
    I am replacing the thermostat and was wondering if the paper gasket is good enough to seal the housings? Should I use some other type of sealant?
    Thanks
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,374
    Media:
    17
    Albums:
    1
    726
    Oct 1, 2003
    MN
    I use a light coat of silicone on both sides of the housing gasket.
    Do you have the seal for the top of the stat to the housing? Should be a black rubber(hard now) ring.
    I also use anti-seeze on the bolts to prevent them from corroding and becoming one with the housing through dissimilar metal corrosion, and I usually put in new bolts too, but if yours are in good condition and not detierorated, you should be fine.
    Good luck!
    -Steve
  3. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,293
    4,134
    Mar 15, 2003
    Sacramento, CA
    Those bolts are the crappiest bolts Toyota makes-I have snapped 2, and I am very careful about stff like that.. I do what Poser does-a very thin layer of RTV-gray-on the housing gasket and antiseize the bolts. If you like having heat- make sure you install that upper gasket on the top of the thermostat. One other thing-Use Toyota gaskets-NAPA sells a set, but the housing gasket is too thick to work properly.
  4. jwest
    jwest
    688
    1
    Mar 12, 2004
    Sounds like a good time to replace those bolts. I should've done that when I was into it 3 weeks ago. Hmm, I guess I still could.... one at a time.
  5. 70LCruiser
    70LCruiser
    187
    1
    May 17, 2003
    Just curious, but does anyone know if they make a chrome thermostat housing for a 1F engine?
  6. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    No, but I am sure you can have your aluminum one chromed for a small fee.
  7. dd113
    dd113
    2,922
    5
    Jun 13, 2003
    [quote author=70LCruiser link=board=1;threadid=13766;start=msg128015#msg128015 date=1080439901]
    [/quote]
    They do and it is the coolest thing. It brightenes up the entire engine compartment. There are chrome valve covers also. I really like them. You can also get some of the fake briaded lines for it. Man, that would be cool once you ge tit done. There is a chrome timing chain cover that is SO bling. You should have it or you aint s***.
  8. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    27
    Jan 3, 2003
    McCall, ID
    Yeah, you add enough of that sheit, and you can rename you truck. Call it a...a....J33P! Drive it over to the mall!
  9. 70LCruiser
    70LCruiser
    187
    1
    May 17, 2003
    no, a crusier will never be a HEEP, but i wouldnt go that far to chrome everything. Im trying to find an aluminum or chromed vlave cover though, anyone know where i can get one??
