Wanted thermostat lower water housing April 1979 (FJ40) (1 Viewer)
Durango Colorado
My lower housing has been eaten thru at the one of the screw areas. I can
find various lower housings online stating that they go up to 1/79. My
FJ40 was however made in April 1979. Not clear what the difference is
so info on what I could get would be nice.
1) I need one lower hemisphere thermostat water housing for April 1979 FJ40
2) I need one NEW thermostat for April 1979 FJ40
If I need to completely switch gears and get a new combo (lower + upper) that
fits the block inlet then thats possible also. My upper water hemisphere has an
oil cooler outlet.
Many thanks, Dave
Dave ,
I have an entire set off of a 77&78 I believe. I thought these were all the same. Picture of what you are looking for?
The ‘79 came with 2 temp sender holes in the lower housing. If you are desmogged and don’t need those sender holes, you can use a lower housing all the way back to ‘68.
I would offer to sell you one , but there are at least 10 guys on here that can offer you one for less than a guy with a bricks and mortar business with overhead.
Incredible info 65swb45! I have been desmogged. Looks like I can also pick up part
16331-60040 off ebay also for 45$.
hoperichb ... if you have a new one in the same ballpark I'd prefer buying from
a fellow mudder. Otherwise I'll go with the new off ebay since its avail and apparently
(given the condition of mine) they fall apart.
That’s what the ‘like’ button is for.;)
I have a used one at that price for upper and lower. At that rate for brand new I’d take it. Let me know if you want it and I’ll get you a picture.
