Hi All,
I just finished replacing the radiator, the main hoses and the t-stat. I had a cracked rad and decided to replace the hoses and t-stat at the same time. Finshed it up and I took it for a drive today and the temperature was running a lot hotter than previously. Before, the temp was usually at ~188-193* consistently on the freeway. Today it was hitting temps as high as 216* on the inclines and in the 200-205* range on the flats (monitoring temps with a scanguage).
I did a search and I think there's one thing I forgot to check on the t-stat; the orientation of the t-stat. I didn't realize the jiggle valve had to be in the 12 O'clock position. I'm not sure if I did this. Could this be the reason why I'm seeing higher temps? The new t-stat is oem. I did leave the cap open when I filled and started it to try to burp the system.
I'm going to see if I hear the fan clutch roar when I start it up in the morning to hopefully rule that out.
Any thoughts?
Cheers,
Salue
Any thoughts?
Cheers,
Salue
