Thermostat Housing (Tappin' that Beyatch)
TJDIV
UP of MI.
Mod Emeritus
UP of Michigan
Website
www.roamwherever.com
Well...
New FJ40 (to me). Take it for a spin and the temp gauge is creeping eerily close to HOT. Felt the hoses, felt the Therm. hosuing, Radiator cap...all felt hot, and I got some dieseling when I turned the ignition off.
So, I go to pop the thermostat out, SNAPPED all 4 Bolts at the head. s***.
Drilled them out, tapped them with a 10mm (too big, but the only one that would work!)
Got set up to re-mount the housing and it leaked from the bolt heads (needed different washers)..so I pulled it off and noticed that one of the fxxxing holes I had tapped had cracked at the corner. There was still enough material to drill through with a 5/16th's and send a bolt all the way through with a lock nut and washer.
I HATE having to "rig" s***.
Anyway. I used that "Black Silicone" gasket sealer and put a significant amount around the base and gasket. Tightened all the bolts (they worked well) and am going to let it set up overnight.
IF THIS DOESN'T work; I will need the thermostat housing assembly that bolts to the head off an 82 FJ40 with a 2F. If you have one, I wouldn't mind getting my hands on it to re-do this "temporary" fix.
If you have one, please PM.
Questions for you hosers then that have done this:
It's been 2 years since I've had a serious cooling system problem, last one was on my girl's Mustang, and I just traded it in.
With the thermostat replaced, what are the chances that I'll have to replace the radiator and water pump?
Did you have to replace anything other than the thermostat?
I was having a fluctuation on my 67 F engine once warmed. It would go from the 170 degree range to 195 degrees. I noticed it most in the mountains. going down hill it would cool off to the 170 range. I replaced the radiator cap because it was one of those piece of crap aftermarket one. I put a new OEM one on ($11) and I have not had a problem since.
I would flush the hell out of the system, fill her back up, run it and see what happens.
I once had a Toyota Corolla, had the same problem. I could never figure out what was the matter. Finally I took it to the thing to Toyota and talked to the Service Tech. he looked it up in one of his service bulletins and Toyota found that you needed to put a 1/8" hole in the thermostat at 9:00. No more problems after that. Amazing what just one little thing will do.
Not that the above has any real relation just that the littlest thing can have a big impact.
Definitely flush the system, Tommy, and don't forget to drain the engine block at the draincock on the driver's side. There is often a lot of crud and you can't flush it out via the radiator. IF you don't drain the engine, all of that crud may fill up your radiator again.
Tommy, I have the thermostat housing and water pump from my '76 2F. The housing is fine; not sure about the pump, but I'm guessing it is OK too. You can have them for shipping plus a few bucks, whatever's fair. Let me know.
theo
TJ, before you flush, disconnect the heater hose, just loop them together with a piece of 1/2" copper tubing and a couple of hoser clamps. Any s*** you knock loose with the flush will collect in the heater core. The passageways are much smaller than the ones in the radiator.
I would use the flush that is a caustic and must be neutralized. Do it twice.
JMO
Ed
And GL
OK.
While I was at work, a buddy of mine pulled the drain plug and started up the Cruiser. NOTHING leaked out of the plug. Apparently I'm not getting any circulation of fluid.
Is this water pump related? Plugged up radiator? Best to just replace everything in the system and KNOW it's good? Looks like having the 40 out on the trail tomorrow night isn't gonna happen.
I've PM'd those who have offered parts. I will take them.
Damn this situation.
Is it the radiator or engine plug that is not draining, Tommy? Or both? It is very common for the engine to be crudded up (see my previous posts on the subject), but not the radiator.
