Stone said:Oh and Nick...I am back to work now.![]()
Thats awesome Stone.
Does that mean your feeling better?
How is your back? Still bugging you?
Is it perminant damage?
And on the less important side, are you keeping the cruiser now?
Cheers,
Nick
Gold Boy said:They mentioned also that there is a possibility of the thermocouple melting off and dropping into there turbo.
GB
denis said:OK Greg sorry for theI guess that's how I like to pick on words and split hairs. The flame front is a spark ignition (SI) term. You have a pretty much homogenous mixture that gets ingnited at one time, one place by the spark, and the combustion propagates from there. In a diesel, long story short the fuel is being injected in a spray of tiny droplets, which spontaneously burn because of the high temperature in the cylinder. Some start burning quicker than some others, locally raising the temps and putting those nearby in adequate conditions for burning as well. At the very begining of the injection the burning zone is somewhat local to the spray but these engines are designed to make the mixture somewhat homogenous as fast as possible putting swirl and/or turbulence in the airflow. That way in an ideal diesel engine a "flame front" would be everywhere in the cylinder and pushing in every direction. At least that's the way I understand it.
brownbear said:I like the harness on your isspro thermocouple. Nice disconnect. The autometer use screws under shrink wrap.
Otterav said:Hey,
As I understand the purpose of the pyro is to determine the safe limits of combustion temperatures due to the relatively low melting temp of aluminum. To gain the most utility from the diesel motor the knowledge of the combustion temp must be known, the fuel must be limited to prevent damage to the motor during the most severe of possible conditions, ie max torque w/high ambient intake temps. This only applies to pre electronic fuel controls in modern engines. The pre-electronic fuel controlled motors were limited by the tuning of the injector pump, modding the engine with turbos and injector pump tuning removes the original engineering design protections and increases the requirment for instrumentation so the intimate internal health of the engine can be monitored. Pre turbo will give the most accurate indication of combustion temps, most post combustion pyro installations are are engineered by the manufacturer for the drop in temps due to the turbo heat/energy extraction by the manufacturer/vendor of the instrument. Most manufacturers of turboed engines specify the required cool down period for a turbocharged engine and use of these guidelines for a modded engine of samr/similar design would be an appropriate starting point.
Gotta love turbos and diesel!
eric
P.S. remember cool down is for more than the turbo, my military truck requires 5-10 minutes cooldown at high idle after "hard running" wether the truck is turboed or not.
My point exactly, change the motor from stock and all bets are offbrownbear said:the electric fuel controlled units also need to be monitored. Especially when doing something out of the ordinary such as towing. Or modified ie tires gears...
The big diesel ford/gm/dodge, when they get "chips' installed then have to also monitor EGts. Cause basically you just fawked with all the parameters.
Otterav said:My point exactly, change the motor from stock and all bets are off
eric
Mattse.cx said:When installing pre-turbo, wouldn't the little metal bits caused by drilling/tapping be bad news for the turbine?
Greg_B, there is no "flame front" so to speak in a diesel![]()
