My cruiser is not starting and I can't find the problem when I turn the key I can ear the relay clicking under the dash but the engine doesn't turn. I've check my batteries they are both good at 26-27 Volts (they where replaced last year), the EDIC arm is moving and my starter and battery grounds seem to be good... what else should I check? Could it be my ignition? When it ran sometimes I could turn off and remove the key and the truck would still run!
I don't think it the solenoid cause I've replaced them about 2 years ago... normally the solenoid would give you a few warning shots before dying completely and my problem started suddenly. I didn't repalce the plunger though? Oh and I can't ear any clicks from the starter.
How do I check the current at the starter? or a bad ground?
use a volt meter on the cable going to the starter...
also try hitting the starter with a hammer or something... I had to hit mine once a week for 4 months, until I came out one day and had to get under my truck in the pouring rain, that's when I remaned mine
Thanks guys! I took some time and opened the starter to notice that my brushes where complete shot so I quess this would be the source of my problem. I'll post a reply when after I have it rebuild.
Tell me more what exactly is a spade fitting and on which wheel arch?
