Just wanted to post this up in case it happens to anybody else as I couldn’t find a thread on this anywhere.
Currently, my 93 FZJ80 has the front driver tire removed and is on a stand because I have to drain the coolant to replace my thermostat and PHH and am going to be changing out some other hoses as well (I posted about it all a few days ago) and I started the rig up as it hadn’t ran in a few days and when I turned off the rig I looked down and I was quickly leaking a lot of transmission fluid from my dipstick tube (I need to replace the o-ring) and I pulled the trans dipstick out hoping to relieve some pressure BUT transmission fluid starting shooting upwards, out of the dipstick tube. So I quickly put it back in and just had to wait it out until the leak stopped. Suspecting it was a ventilation issue we figured it’d be worth a call to our mechanic to get his thoughts. He said he hadn’t seen it before but also suspected it was a vent issue.
And sure enough, after a lot of looking, feeling, and cussing we were able to find the transmission breather plug (it is not easy to access at all and impossible to see without a camera / small mechanical mirror of some sort) and we found that the transmission breather hose had gotten kinked at the plug causing the pressure problems. Once we got the hose removed we started the truck, let it run, and turned it off, and the leak was gone. Still have no idea how it happened, how it could have happened, etc. as it had never been an issue before. Thankfully, it happened when the truck was already on stands for the other work and was just a hose, not the tranny itself. We’re going to use this opportunity to replace that hose and extend the transfer case & transmission breathers and fit them into ARB breather set up I did with the differentials a few months back.
Hopefully if anybody else ever has this issue they can find this, just figured I would try and provide something useful to this forum as so many of you have helped me already.
