I thought the deck height was different between the 22r and the re. I once got an engine from somebody that said that it was a rebuilt re. It was rebuilt but he put a 22r head on it and it would not work. The pistons would hit the head when I would try to turn it over. And yes the valve timing was right.
Correct.
But, a doesn't carb head have bigger valves then an EFI head ?
22R cylinder heads have a open/raised combustion chamber
22RE cylinder heads have a closed combustion chamber
Is this true?
Nope. Do you have any data to the contrary?
so with the difference you might see a 1-3 hp loss/gain i figure
