Build "The Survivor" 09/1990 (MY 1991) HZJ77 Refurbishment and Renewal
Status
Not open for further replies.
Some more updates…
New BMC:
@Onur if you wouldn't mind taking a pic of the injection line routing when you get to that point? I just installed the pump you sold me (i got it rebuilt) and could use a good visual reference again.
New Sumogear long spline input gear…
This gear replaces the OEM input gear, spacer and PTO gear. A good upgrade if not running any PTO:
New idler shaft, bearings, washers, o-rings, and the idler gears installed:
And your high low gear set with new bearings installed:
Detent ball, spring and plug for the high-low shaft:
Installed here:
Speedo gear, spacer and washer on the rear output:
You can see here the OEM marking indicating gear tooth count for drive and driven gear:
Input bearing installed:
Make sure to locktite the set bolt for the idler shaft tab…. If that backs out…. The whole thing goes kaboom…. :lol:
Thanks to my good friend Georg @orangefj45 for the rebuild kit and long spline gear…. Pimp.
Rear extension housing installed:
Front and rear drive flanges installed and staked:
Input shaft staked and covered:
And complete:
I really wish I could have powder coated the case like I normally do, but due to some life changes we had to cut that aspect short to get the truck out back together and driving. I have a solid drop-dead date of next Weds for this rig…. So lots to do!
More soon.
Status
