The SOA closeup picture thread
Cdaniel
Undocumented Mechanic-I Am Not CDAN
AZ
Website
zot-art.com
While searching around for pictures of SOA setups, I found myself wishing there was a thread dedicated to it. So I'm starting one. Here's some pictures I found of the multitude of approaches to the same mod. Hanger, shackles, perches etc.
Hopefully others will add to this.:wrench::wrench::wrench::wrench:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Great idea for a thread!
Anybody got pics of through-frame shackle or other ideas for a "lower" SOA?
It would also be cool to get part numbers for spring mounts and just misc parts used in most SOA setups.
My SOA, Ruff Stuff and Marlin Crawler componets.Alcan springs, Saginaw conversion, cut housings, 4 wheel disk brakes
Idea for lowering a spring over - I saw this on a Toyota in Moab several years ago and snapped a couple of pics. This is on the rear spring. I suppose it could also be done on the front springs...
Several pictures of how I've done SOA on 40/45's I've built:
-Extend the frame horns 2"
-Plate the inner frame horns
-Plate the crossmember
-Built front hangers and weld to frame
-Build saginaw mount plate with 2 upper bolts going through frame. (frame is sleeved).
-Front spring shackles are through the frame using 1" id tube.
-Custom built ubolt plates
-Frame horns are tied together with crossmember
Just happened to open this thread...... I found my rig during the building process in the first two photos!
great thread.
great thread.
I was thinking maybe I should of added attribution to the pics, but got lost with all the cutting and pasting of url's:p
Anonymous fab inspiration till the real owners pipe up :cheers:
great thread.
lol...one of my 40s is the pic right above your post ;)
here are some more early pics
only thing purchased was consumables and dodge spring perches. reused the rear mounts in the front, cut the tubes from the front mounts to weld in the frame in the rear.
